how to Live Trace with transparency?
COW Forums : Adobe Illustrator
sergio juyak
on Jul 20, 2009 at 2:12:04 am
I am unable to use live trace to trace an image in black and white while still retaining the alpha. I have tried pasting and placing the image and no luck. "The ignore white" checkbox doesn't get me any further.. no mater what i do, livetrace merges the white hilites with the alpha.. As an example, i show a donut, and how AI fails to acknowledge the alpha. Can someone explain how to trace this donut properly?
<img src="http://img31.imageshack.us/img31/4328/trace.png" border="0">
Vincent Rosati
Re: how to Live Trace with transparency?
on Jul 20, 2009 at 11:31:03 am
Select the traced object, than Object/ Expand.
Than, select the Group Selection Tool, drag it over the border of the trace, and delete.
Vince
Vincent Rosati
on Jul 20, 2009 at 2:40:24 pm
I just read your post again. Another part of your issue is that you're losing the inner and outer shape. correct?
You could redraw those elements after the trace.
Or, adjust the trace setting, so you don't lose the object's structure.
Or, darken or saturate the image in PS, prior to tracing in AI.
Vince
