Photoshop to Illustrator
COW Forums : Adobe Illustrator
Reggie Spires
on Jul 11, 2009 at 3:11:55 pm
Best File format coming OUT of Photoshop to due a live trace in Illustrator when the Photoshop Image is on a transparent Background.
Reggie
ps End result is Zaxsworks invig pro inside of AE
Vincent Rosati
Re: Photoshop to Illustrator
on Jul 11, 2009 at 5:35:07 pm
I like TIF/LZW
Vince
les nemeth
on Jul 13, 2009 at 5:44:42 pm
It really doesn't matter. If you want the best result, you will always end up needing to trace using the pen tool. Otherwise you will only get an amateurish end result no matter how you slice it.
Herm Medina
on Jul 15, 2009 at 2:36:22 pm
I typically use PNG; the format is very clean with respect to hard edges unlike JPEG and is usaully quite small (byte-wise). Hope this helps!
