Creating a Continuous Gradient of a Group of Outlined Text
COW Forums : Adobe Illustrator
Kyrsten Sanderson
on Apr 15, 2009 at 9:50:24 pm
Maybe someone can help me with this one...
I have a group of outlined objects that I want to apply a continuous gradient to. When I select all the objects and apply the gradient it applies the gradient to every object instead of treating the object as a group.
How do I apply a continuous gradient to a set of separate objects?
I would appreciate any advice.
Thank you!
adolf witzeling
Re: Creating a Continuous Gradient of a Group of Outlined Text
on Apr 16, 2009 at 12:23:36 pm
select all the outlined objects, then go to OBJECT...COMPOUND PATH...MAKE. Then apply your gradient.
Hope that helps,
cheers,
Adi
Thie Thomsen
on Apr 16, 2009 at 2:30:51 pm
Select the objects you would like to apply the gradient to, select the gradient in your swatches and use the Gradient tool (hotkey : g) to draw the gradient over all on the selected objects.
The compound path way (as offered by Adolf) also works, but this method is a bit less destructive.
I can see your spot colours...
