Cannot stetch shapes?
COW Forums : Adobe Illustrator
Tom Scott
on Apr 9, 2009 at 2:28:04 am
Hey im fairly new to illustrator, it has been working fine until recently.
With the normal cursor i cannot drag and stretch objects instead i have to use the specific tool, to scale objects.
This is really frustrating so even if it sounds like a stupid question you help would really be appreciated, thanks
im using adobe illustrator CS3
Thie Thomsen
Re: Cannot stetch shapes?
on Apr 10, 2009 at 2:21:57 pm
What pointer tool are you using? The white or the black one.
You can't scale with the white one, as this one is specifically for moving/selecting anchorpoints/lines. The black one is for moving/stretching entire objects.
I can see your spot colours...
Tom Scott
on Apr 10, 2009 at 11:06:51 pm
yeah im using the correct cursor, but it seems as though somehow the attributes have copied to the other cursor
thanks for the response
Thie Thomsen
on Apr 11, 2009 at 9:51:00 am
in that case it sounds like you've accidentally hid your bounding boxes.
ctrl+shift+b toggles them back on (command+shift+b on a Mac).
