Import SWF into illustrator
COW Forums : Adobe Illustrator
Larry Bang
on Apr 1, 2009 at 11:17:43 am
Hi there
Does anyone know if its possible to import an SWF file into illustrator (so i can adjust each frame individually)? I'm using CS4
Any help appreciated
Larry
cowcowcowcowcow
Abraham Chaffin
Re: Import SWF into illustrator
on Apr 6, 2009 at 4:25:35 pm
If you have Adobe Flash you can export a fla as an ai file under File > Export then choose .ai as the file type to export.
There's no way to directly import an swf into ai as the file types are not compatible. A swf is a compiled Flash application not really a graphic or movie though it can be used as one.
Abraham
Larry Bang
on Apr 6, 2009 at 5:18:33 pm
Thanks Abraham
Kalani Bright
on Jun 12, 2009 at 12:26:49 am
I had my computer forgotten then stolen and had completely lost the source code and art assets to the flash site I built. I was able to get some of this back by decompiling, opening the decompiled fla, and exporting the art assets I dragged onto the stage to an .AI file.
The code was completely mambo jambo and I elected to toss it, but at least I saved the art assets.
whew.
Jorge Julian
on Nov 27, 2011 at 7:48:27 pm
Although this response is 2 yrs too late, someone in the future will have the same question and I have not seen anyone properly answer it (at least to my satisfaction).
What you can do:
1) Create a new document in Flash
2) File > import > import to stage
3) Scale all the elements so that they fit on the stage
4) File > Print > PDF > Save as Postscript
5) Give it a name and when done...
6) Open it in Illustrator! ;-p
