Add email hyperlink to jpeg in Illustrator CS3
COW Forums : Adobe Illustrator
Davida Pitts
on Feb 26, 2009 at 4:18:54 pm
I have a quick question.
I just finished up a flyer that I sent to a client in jpeg form.
The flyer itself contains an email address for folks to rsvp for the event.
The client will be sending the jpeg as an attachment.
Is there a way to create a hyperlink to the jpeg i am sending to the client so that folks can click the email address in the flyer and their mail client pop up?
Dave Johnson
Re: Add email hyperlink to jpeg in Illustrator CS3
on Feb 27, 2009 at 2:22:49 pm
If Illustrator has that functionality, I've never heard of it.
However, I do what it sounds like you want to do all the time. I use Outlook email so that's the only detailed description I can offer, but you can accomplish the same with most any email program and the steps will be very similar.
With Outlook, you start a new email and select "Insert > Picture > From File". This adds your image to the body of the email (instead of as an attachment). Right click on the image and select "Format Picture" to scale it and whatever other layout functions you may need. Then, select the image, go to "Insert > Hyperlink", type in the URL (or email address) and you're done.
