Vectorizing symmetric logo: tips?
COW Forums : Adobe Illustrator
Eric Chard
on Dec 27, 2008 at 8:02:58 pm
I've got to convert a bitmap mandala to a vector representation. This mandala is symetrical on 2 axes, that is, it's the same pattern rotated 90 degrees 3 times.
I'd PREFER to do this in Photoshop, but I'd also like to do only ONE QUARTER of the thing since it repeats. But I know of no method to repeat a shape and merge them in PS, although Illustrator probably has the capability easier. I just don't know Illustrator nearly as well.
Should a just bite the bullet and use Illustrator, or is there a way to merge shapes in PS?
Tnx!
E
"Putting the HARM in 'harmonica' since 2005."
Zack Ng
Re: Vectorizing symmetric logo: tips?
on Feb 21, 2009 at 3:34:41 pm
It is much easier to merge shapes in PS. If its a "shape", you'll have to rasterize it first, duplicate them, adjust them to the positions you want, and flatten(Ctrl+E) them together. Whereas in Illustrator, you will have to duplicate, and and adjust, and use the pathfinder to merge them together. Kudos!
Freak, I almost didn't want to post due to the registration. Anyway, good luck with it!
