How can I make text fit a shape, not just follow a path?
COW Forums : Adobe Illustrator
jess mol
on Dec 1, 2008 at 8:42:36 pm
Hello,
Is it possible to draw a closed shape using paths and then make some text fill the inside of that shape?
This would be like text following a path but instead of just using it as a baseline it would stretch the width and height of the text to follow the full interior of the shape.
It's something that's very common on badges and logos.
Distort or warp doesn't work because of the kind of shape i need to use.
http://i366.photobucket.com/albums/oo103/spydrwoman11/lakeloon.jpg
I know there are tricks that can be used on raster text to create simple shapes such as bulging or squeezing the centre using lense distortion or other features, but I'm more interested in making text follow irregular (but precise) shapes, preferably using vectors/paths like the current text-to-path feature does.
Many thanks.
Mike Gondek
Re: How can I make text fit a shape, not just follow a path?
on Dec 2, 2008 at 1:10:04 am
This is very easily done in Adobe Illustrator.
Select your type and path (make sure your path is above your type in the layer stacking order)
Object >> envelope Distort >> make with top object
