Adding New Fonts to Illustrator and Photoshop
COW Forums : Adobe Illustrator
Zeno Pierre
on Nov 12, 2008 at 6:13:00 pm
Hi all,
How do I add a new font to Illustrator and Photoshop?
Thanx in advance.
Zee
Jeff Kelley
Re: Adding New Fonts to Illustrator and Photoshop
on Nov 12, 2008 at 8:19:18 pm
On a mac, it's whatever you computer has installed. You don't add them directly to the programs. I assume a PC is just the same.
http://www.willinois.com
Zeno Pierre
on Nov 17, 2008 at 11:01:36 pm
Hey thanks guys.
That did the trick.
Alan Stephens
on Nov 17, 2008 at 9:59:07 pm
You just copy your new fonts into the Macintosh/Library/Fonts folder.
They will then appear in PS & any other text program. I found out by observation you can use tru type fonts on the Mac.
In Windows go to control panel/fonts and use the install feature.
Alan Stephens
Stal Sin
on Apr 16, 2009 at 12:15:00 am
I've added fonts to my system, and restarted illustrator, but can see fonts in panel of illustrator. Should I uninstall/reinstall fonts again?
Onye Nnadi
on Oct 1, 2009 at 2:58:34 am
If your using a Mac, go to dafont.com and download your font file. Then go to, Finder/Application/Fontbook, then open Fontbook, drag and drop your downloaded file into the Fontbook "collection" panel - it should load your font with no problem. Then restart your Illustrator or Photoshop.
Please send me an email to let me know if this works for you-it worked for me.
