Distressing a Logo in illustrator
COW Forums : Adobe Illustrator
Chris Heuer
on Oct 29, 2008 at 2:35:52 am
Hello! I use Illustrator for basic, clean vector (pen tool) logo creation. That's about it. I'm trying to distress a logo for a T-Shirt design. I want it to have grungy or marbled holes through the logo. How/can you do this in Illustrator?
Thanks, Chris
Chris Heuer
Freefall FX, LLC
Chris Heuer
Re: Distressing a Logo in illustrator
on Oct 29, 2008 at 2:57:47 am
Ahhhhhh! I found opacity masks in Adobe help! That's a good start. If there's any other wisdom out there, I'd still be glad to hear it.
Chris Heuer
Freefall FX, LLC
Lasse Haslev
on Oct 30, 2008 at 10:42:17 pm
I donĀ“t fully understand what you want with it.
But if you want an angry design holes in your element you could try this:
Go to google.com and Search for "Brick wall" Find a nice clean brick wall, large or extra large picture.
Then, save it to your mac/pc and open the picture in illustrator.
Click on the picture, go to Object/LiveTrace/Tracing option
Make sure you have the mode in black and white, play alittle with the settings until it is perfect.
Then click trace. Then you have to click Expand.
Now click on the white with the Direct selection tool, and the click, Select/same/fill color then remove the color.
Now take your element under the "brick wall"-layer, select both the layers and click "Subtract from shape area" on the Pathfinder. When you click expand you wil now have a rughy design!
Herm Medina
on Jul 15, 2009 at 2:52:52 pm
You can try the roughen effect if you want to stay totally vector. effect-->distort & transform-->roughen
