PDF's from Illustrator - Problems with Trim Marks
COW Forums : Adobe Illustrator
Natasha Buthee
on Sep 9, 2008 at 3:04:31 pm
Hello, I hope someone can help me.
I have always had difficulties with bleed and trim marks when saving files as pdf's from illustrator. They never seem to be included on the pdf no matter what I do.
Just so you know I am used to saving as pdf's from Indesign and that always works!
Is it something to do with my illustrator settings? Any help would be most appriciated as its doing my heeeeeed in!!
Cheers
Tasha
Jeff Kelley
Re: PDF's from Illustrator - Problems with Trim Marks
on Sep 9, 2008 at 9:48:16 pm
I assume your "saving to pdf". If so, make sure you have you bleeds and mark on the the first dialog box that pops up
http://www.willinois.com
