illustrator cs3 vector question
COW Forums : Adobe Illustrator
dennis moulton
on Aug 25, 2008 at 8:37:38 pm
i have illustrator cs3 and i also just purchased a vinyl cutter. now for the vinyl cutting software i need to convert an image to a vector or path format. (eps, ai, ect)so i start with getting an image i want, usually a jpg image. then i put it into illustrator. this is where i've tried everything to get the shape of just the picture. everytime i import an image it brings just the rectangle around the whole image. i don't want to cut a rectangle but the object inside.
Todd Morgan
Re: illustrator cs3 vector question
on Aug 28, 2008 at 9:14:45 pm
It's called LIVE TRACE and is an option when you have the image selected. It works on high contrast or b/w images and there are a variety of pre-sets. Otherwise, you are looking at creating the vectors by hand.
