AI Box outline
COW Forums : Adobe Illustrator
Rocky Lam
AI Box outline
on May 12, 2008 at 7:45:11 pm
I am using AI to create logos. For example the logo is retangular shape with blue background. When I place that logo in another document with same blue background. I see the white outline of the logo. How can remove that white outline so the logo blend in with the rest of the document?
joe rugby
Re: AI Box outline
on May 12, 2008 at 8:34:08 pm
Its likely a stroke on your rectangular path. Highlight the rectangle--open the stroke window and set stroke to 0.
Cheers,
Joe
L.O.A.
Rocky Lam
Re: AI Box outline
on May 12, 2008 at 8:51:34 pm
I tried the window strobe is still shown the border line.
adolf witzeling
Re: AI Box outline
on May 13, 2008 at 5:52:53 pm
Are you placing the Illustrator file in InDesign?
If yes, go to VIEW...HIDE FRAME EDGES.
See if that helps.
cheers,
Adi
Rocky Lam
Re: AI Box outline
on May 13, 2008 at 9:24:47 pm
I am placing the logo on an Excel sheet document. I am working on pricelist documents.
adolf witzeling
Re: AI Box outline
on May 14, 2008 at 2:39:59 pm
Oh, ok.
In Illustrator, before you save the logo, go to EFFECT....RASTER EFFECT SETTINGS.
In the Options check CREATE CLIPPING MASK around the logo. Make sure the "add ... around object is set to ZERO.
Maybe that'll work.
cheers,
Adi
