enable/disable an fx on an object
COW Forums : Adobe Illustrator
Stephan Dube
on Apr 25, 2008 at 2:16:31 pm
Hello all
is there a way you can enable/disable an fx on an object in illustrator?
thanks
cheers
Vincent Rosati
Re: enable/disable an fx on an object
on May 2, 2008 at 2:05:50 am
Select the object than open Window/Appearance. You can delete an effect, but I don't think you can toggle it. If you need to save an effect you can drag the fx object into the Graphic Styles palette.
Vince
