creating a wireframe image from a jpeg
COW Forums : Adobe Illustrator
Dwight Spitz
on Feb 7, 2008 at 10:33:17 pm
Specifically, taking a jpeg of FZ Frank Zappa's mug, in order to create a wire frame of the moustachioed one, in idea would be regally appreciated. tanks...
Vincent Rosati
Re: creating a wireframe image from a jpeg
on Feb 8, 2008 at 2:25:15 am
I'd open the JPEG with Illustrator, lock the image layer, double click on the image layer in the Layers palette and check the 'Dim Image...' box.
Create a new layer and use the Pen or Pencil tool to illustrate the raster image.
You can, than, make adjustments to the strokes by adjusting line weights, applying brushes, or whatever.
You could also use similar techniques in Photoshop.
Vince
Dwight Spitz
on Feb 8, 2008 at 5:09:44 pm
thanks Vince, when you say "illustrate" do you mean actually draw? Cause I was looking for something a little less hands on, see i'm not much of an illustrator, lemme see if I can find a link to an example, hopefully thats allowed
http://i46.photobucket.com/albums/f129/josalgarcia/wireframe01.jpg
this is more or less what i mean, something along these lines, scuse the pun;]
http://www.flickr.com/photos/coal2k/89207450/
Vincent Rosati
on Feb 9, 2008 at 3:51:02 am
lol. :) The easiest way I know that would enable you to produce something like your example would be to use Poser 5 (or better).
It's an easy to use 3D modeling program. It simply uses parameter dials to 're-sculpt' preset human figures, or heads in your case. The trick might be creating the moustache and hair, depending which period in ol' Z's life you were referencing - which you would have to model in a 3D app.
I don't have an easy answer for this one. :(
Good Luck.
Vince
Dwight Spitz
on Feb 9, 2008 at 5:42:50 am
thanks Vince i really appreciate the suggestions, i will now figure out how to use poser 5 on a pc. i'll let you know how it goes
Vincent Rosati
on Feb 9, 2008 at 7:29:30 pm
Definitely, let me know. :)
If you get a chance, fill out your profile so we can see your system specs.
Vince
