Illustrator - 'document size' vs 'displayed size'
COW Forums : Adobe Illustrator
gunnar
on Dec 18, 2007 at 4:37:54 am
it's a simple one and if there would be a 'Read First' I would have checked it....
if I have an illustrator document in let's say 120mm X 90mm. Why is the displayed size (100%) so much smaller and do I have to worry about that?
Maybe it's just an Scrren Resolution issue, or so?
I want to print the designed thing later, so it matters to me.
thx
Gunnar
Richard Harrington
Re: Illustrator - 'document size' vs 'displayed size'
on Dec 19, 2007 at 2:33:39 am
Display size has nothing to do with print size.
Look at your Docuemnt settings to see print size
Suggest you get started with the Classroom in a Book and build a solid foundation
Gunars Ratnikovs
on Jan 3, 2011 at 10:51:59 pm
hello. I have illustrator print document size 2m x 11m . how can i set it up, when i am trying to do that it keeps me saying that it has to be max 577.xx cm.. help asap! thanks!
Vincent Rosati
on Jan 4, 2011 at 6:02:29 am
Make your document 1/2 scale - 100 cm x 550 cm.
Or smaller, 1/4 scale - 50 cm x 275 cm.
Vince
*Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
