Remove Jaggy Edges Photoshop
COW Forums : Adobe Illustrator
nexter83
on Nov 16, 2007 at 1:53:38 am
I have an image which I need to remove the jaggy edges from. The jaggy edges aren't bad enough that I think it has to be redone - I thought there might be a way to just smooth the edges out. I read someones post about using a blur and then moving the levels to sharpen the edges, however, I didn't have any luck with that.
Does anyone have any ideas?
I have the psd online so you can see what I am trying to do.
http://www.butlerfumc.com/test.psd
Any help would be appreciated! Thanks!
pixelmeister
Re: Remove Jaggy Edges Photoshop
on Nov 16, 2007 at 11:47:40 pm
hi,
try these settings in Illustrator CS2.
Place the Photoshop picture in Illustrator.
ADJUSTMENTS
1: select the picture withe selection cursor...
2: choose LIVE TRACE from the menue and in the Tracing options to start out, try these settings:
Mode: Black and White/ treshhold 128/ Blur 1.3 pix
TRACE SETTINGS
path fitting: 2 pix
minimum area: 10 pix
corner angle: 20
Play around with these setting, experiment, it's fun...
you can get all those different looks....
take care,
Adi
nexter83
on Nov 18, 2007 at 2:51:10 am
Great - Thank you for your help!
