Wrapping text around a globe
COW Forums : Adobe Illustrator
lackner90
on Oct 30, 2007 at 7:14:34 pm
Hello,
This is actually a question for Photoshop CS2.
Sorry but I really need an answer.
I created text wrapping around a globe easily using the CC Cylinder effect in After Effects.
Is there a way to do the same exact thing to text in Photoshop CS2 or Illustrator CS2?
Thanks so much in advanced and sorry for postin on AE forum
Mike Gondek
Re: Wrapping text around a globe
on Nov 1, 2007 at 6:57:09 pm
Illustrator
Object >> Envelope Distort >> make with warp
Photoshop
I believe it is under edit >> transform >> warp. You need CS2, I am working somewhere today with only CS1.
You can also export a frame from your AE file to a still image format like tif if needed and your already have this distored in AE.
