Feathering
COW Forums : Adobe Illustrator
skimber
Feathering
on Oct 24, 2007 at 4:12:24 pm
I'm not sure what's happening, but I'm having difficulty putting a feather on a vector layer that I've created. If I use the circle shape and put the feather on that as is, it works fine. However, if I try to make the shape larger, either before or after I put the feather on it, the feather disappears and won't work, even though it still registers in the appearance palette. This is also true if I just try and draw a large circle with the pen tool. I can't get the feathering to work. I've even tried to add about 30 feathers just to see if maybe the object was too big for the feather to be seen, but it still won't show up. Any suggestions?
Sean
skimber
Re: Feathering
on Oct 24, 2007 at 5:39:56 pm
I forgot to mention that this was in Illustrator CS2.
