AI object with alpha
COW Forums : Adobe Illustrator
scott59
on Jul 31, 2007 at 8:37:35 pm
I'm very new to Illustrator. How do I export an object I have drawn in Illustrator, bring into after effects but key out the background for animation in AE.
Vincent Rosati
Re: AI object with alpha
on Aug 2, 2007 at 9:02:32 pm
You can import the AI file into After Effects, than drop it into a layer.
If you have a closed path that outlines you subject in the Illustrator file you can use that as a layer mask in After Effects. Just copy the path in AI, than select the layer in AE and paste.
Do you need a mask, or could you just delete the unwanted parts from the AI file?
