copying effects in illustrator
COW Forums : Adobe Illustrator
criis daw
on Jul 16, 2007 at 8:55:21 am
Maybe i am being a dumb ass, but i have a 3d bevel effect on a text layer in illustrator CS2 and i can't find a way to copy this effect onto other text layers .... Any ideas
cheers
pixelmeister
Re: copying effects in illustrator
on Jul 16, 2007 at 6:28:52 pm
Hi Chris,
Select the effect (in the layer palette open the layer triangle, then select the "effect")
and while holding the OPTION key click and drag the little (target) circle to the right
and drag it to the new layer. This will apply the effect to the object on the new layer.
Hope that helps,
Adi
Mike Gondek
on Jul 16, 2007 at 7:11:12 pm
You can also use the eyedropper tool to copy or apply effects. Just make sure you doubleclick the tool first and configure it properly.
For example you will want appearance checked, and character attributes either checked or not checekd if you do not want to pick up the typefont specs.
