Pagemaker to Illustrator
COW Forums : Adobe Illustrator
Jack Stone
on May 23, 2007 at 5:43:37 pm
I do not work in Pagemaker. I have a client that has created assets in Pagemaker and he would like to import or open them in Illustrator. Can it be done? Any help would be much appreciated.
Jack Stone
pixelmeister
Re: Pagemaker to Illustrator
on May 24, 2007 at 1:01:20 pm
yes it can be done in several ways.
In Pagemaker go to FILE...PRINT...set everything up like you would if you would print to a real printer. In ...OPTIONS...in the PM print dialog choose...WRITE POSTSCRIPT TO FILE...
choose...EPS....PRINT
PM will create an eps file that can be opened in Illustrator...you will need to load the fonts that were used in PM.
OR: Create a pdf from within PM, but do not embed and subset the fonts.
That way assuming you have the fonts loaded it will nicely open in Illustrator with all fonts live and editable.
Hope that helps.
-Adi
