3D Plugin for CS2 Illustrator
COW Forums : Adobe Illustrator
BayDog
on May 14, 2007 at 11:08:35 pm
Hey gang,
Is their an affordable 3D plugin for Illustrator CS2?
Michael
Mike Gondek
Re: 3D Plugin for CS2 Illustrator
on May 16, 2007 at 6:13:50 pm
Illustrator has a 3d plug-in already built into the program since CS1. Effect >> 3D >> (you havev 3 hoices here such as extrude, lathe, rotate)
Is there something else you wanted Illustrator to do. KPT Vector effects is a classic and still works on the PC AICS2 atleast, but I believe it stopped working on the mac.
BayDog
on May 16, 2007 at 6:19:14 pm
Yeah,
The 3D plugin that comes with it is kind of wankey.
I used to use Vector effects too but it doesn't work on CS2.
If you know of a cheap plugin for CS2 that would be great.
BayDog
Mike Gondek
on May 23, 2007 at 1:41:09 pm
You must be on a mac since KPT vector Effects is not working in CS2. Too bad it only works on the pc.
I don't have one of the new intel macs, wonder if KPT_VE works on that????
