Is it possible to do a stroke without curved edges?
COW Forums : Adobe Illustrator
DanielHaskett
on May 14, 2007 at 12:10:19 pm
Hi there
Well basically when you apply a layer style to a layer with a stroke, it always gives the stroke rounded edges....is it not possible to have on with straight edges if it is for a box for instance? i know when you choose "inside" it kind of does but then u loose the edges of the image...
thanks in advance!
dan
Mike Gondek
Re: Is it possible to do a stroke without curved edges?
on May 14, 2007 at 2:59:47 pm
Sorry but stroke layer styles setting to inside is the only way to do this, and I have been pushing these type of bread & butter features on the Adobe beta's for years.
Illustrator works much better for strokes. You can copy your photoshop stroke into illustrato as a vector path, stroke it in illustrator and then bring that in as a smart object. I fill with the illustrator path same color incase I am off by a pixel.
