transform handles have disappeared
COW Forums : Adobe Illustrator
indian_tut_guru
on May 14, 2007 at 10:25:04 am
hi
i have illustrator CS2 installed on windows vista home OS.
my problem is that recently my transform handles have disappeared. every time i have to scale down anything i have to use scale tool. no transform handles r appearing.
how can i get 'em back.
thnx in advance
Mike Gondek
Re: transform handles have disappeared
on May 14, 2007 at 2:35:24 pm
Try resetting your illustrator preferences. Since you said this used to work good chance this will be fixed.
If you had a huge rectangle outside the canvas on your page, and you do a select all, it may appears you lost your transform handle, as they are just outside your view area. Most likley my first suggestion is your solution, but mentioning this as I once had someone in a class in that situation.
indian_tut_guru
on May 15, 2007 at 11:07:54 am
hi
thnx for ur reply
where should i reset my preferences. i went to file preferences but there is the option to reset warning dialoges.
how to reset preferences in illustrator cs2
regards
Mike Gondek
on May 15, 2007 at 1:21:48 pm
Immeditely after booting illustrator hold down these 3 keys (Shift Ctrl Alt) until prompted about do you want to reset your prefs.
Melody Sandola
on Jun 4, 2008 at 3:28:59 pm
Under View click on show bounding box. This was driving me crazy too!!!
Chris Fraser
on Mar 15, 2010 at 8:09:43 am
Such a simple solution, this has been bugging me for years! Thanks!!
lukman hakim
on Mar 7, 2014 at 3:19:43 am
I think, to restore auto transform in illustrator as seen in the picture attachment sent it, you just press Shift + Ctrl + B or select View - Show Bounding Box. that's it!
I hope this can help
