making .jpegs look their best when output to video
COW Forums : Adobe Illustrator
on Apr 19, 2007 at 12:47:40 am
I know that interlacing a .jpeg makes it look better when exported to video or an editing system like Avide. But does anyone know anything else that should be done to them in Photoshop? Thanks.
Re: making .jpegs look their best when output to video
on Apr 20, 2007 at 12:55:51 pm
Interlacing a still is impossible..interlacing is something that happens to video - if you take a still shot from a video sequence and it is interlaced, you will probably see lines in the still.. this is the combinaiton of the 2 fields that make up that frame. de-interlacing a captured still in Photoshop can sometime fix this, but not always.
If your still has NOT been created via video (ie: it is a still photograph, a scan, or something you've created from scratch in PS/Illustrator or whatever then you dson't need to worry about interlacing.
Stuff to look out for though:-
- Make sure it is in the correct colour space, size and aspect ratio for the intended video type it is going to (Photoshop CS1/2 have presets for this when you create a new document)
- Make sure any type is more than 17 pixels high (measure the height of a lower case 'x') if your video is to be broadcast and it is legal type.
- Keep your colours/luminance values between 16-235 for NTSC broadcast, or 0-255 for PAL.
- Make sure you don't have any very thin horizontal lines or fine type, as these will 'dance' on a TV screen and look really ugly.
- Adhere to the title and action safe guides in your photoshop document, as a varying percentage of the outer frame will be cut off on TV screens. If your video is for UK broadcast you must use a tighter title safe to protect blow up of the picture to 14:9. Search the BBC website for info on this.
- Your best bet if you're creating graphics for TV alot is to get something like a Blackmagic Decklink card and then you can monitor your output on a TV or a boradcast grade monitor if you have access to one. you hit a hotkey in Photoshop and your output pops up on your TV/monitor. A cheap way of doing this is via firewire in Photoshop CS2, but you'll need a TV with a firewire input of get a converter.
PHEW! Hope some of that was useful.
*Production Studio Premium / *Combustion 3
Win XP Pro SP2 / Intel P4 3GHz / 2GB RAM / GeForce FX5200 / DeckLink Pro / Sony BVM-20G1E / DVS SDI Clipstation / 110GB boot/80GB media/600GB RAID-0
© 2018 All Rights Reserved
