Illustrator: Can't get stroke smaller than 1 pt. Why???
COW Forums : Adobe Illustrator
Kovboy
on Apr 17, 2007 at 12:17:31 pm
I use illustrator, but I can't set the stroke weight smaller than 1 pt. I
Mike Gondek
Re: Illustrator: Can't get stroke smaller than 1 pt. Why???
on Apr 17, 2007 at 1:48:33 pm
Your illustrator preferences may have gotten corrupted. Try resetting them.
Kovboy
on Apr 17, 2007 at 9:10:16 pm
How do I reset them?
cow
Kovboy
Solved!
on Apr 18, 2007 at 7:18:36 am
If the language of the operating system differs from the English Illustrator installation there may be problems. I use another OS language than english, and use COMMAS "," instead of DOTS "." when I write numbers.
Illustrator some way or another can't parse the 0.25 or 0.50 when I choose it with the cursor or scroll through the numbers with my keystrokes. I have to type the stroke weight with COMMAS not DOTS.
Example:
If I want to get 0.5 thickness. Do get it to work I have to type in "0,50" not "0.50"
Mike Gondek
Re: Solved!
on Apr 18, 2007 at 3:14:38 pm
Thanks for the follow up and letting us know, always interested in what solves a graphics problem.
Is Kovboy Eastern European for Cowboy? I know in Polish it would be Kowboy.
Kovboy
Re: Solved!
on Apr 26, 2007 at 6:43:47 pm
Not Eastern European, but
Mike Gondek
Re: Solved!
on May 9, 2007 at 2:40:00 pm
Great to have people from so many interesting places on this board.
lloyd lloydson
Re: Solved!
on Jun 5, 2009 at 6:51:01 am
You can make your stroke smaller than 1pt. No problem
The only problem is that your 'regional language options' are different from your Illustrator version.
First of all you can always manually type in your stroke weight, if selecting the weight doesn't work.
Short way:
Do the things the picture tells you
http://img29.imageshack.us/img29/9060/fixedvss.jpg
Long way (with explanation):
To fix this go to the Control Panel, and choose "Regional Language Options"
Next select the tab "Regional Option" and then press "Customize"
Look at your stroke weights in Illustrator, see what punctiuation is used for smaller strokes than 1pt.
If for example there is a komma used (0,25 pt), you change the "Digit grouping symbol" also into a komma. The same procedure is used for a point.
lloyd lloydson
on Jun 5, 2009 at 6:49:17 am
Short way:
Simon Hough
on Feb 11, 2013 at 8:38:44 pm
I know this is an old post but I thought It would be best to write a reply here.
I'm using Illustrator CS6 and I'm having the same problem. I cannot change the stroke width to less than 1 pt. Except the problem occurs regardless of whether I type the value in or select it from the stroke weight panel. Also it only occurs when I select two or more strokes of varying width first and try to use the stroke panel to adjust them to the same value.
I tried going to Control Panel > Region and Language and then clicking the Formats tag. Selecting Additional settings and then changing Digit Grouping symbol to a period instead of a comma.
I also tried changing the stroke width to none to try and reset it. Nothing seems to work. The solution would be to adjust each stroke individually but there has got to be a better way
I've uploaded a 1 minute youtube video demonstrating the problem. You might have to maximize the youtube video screen to see it more clearly.
Thank you
Simon Hough
on Feb 11, 2013 at 9:01:58 pm
Unfortunately I am now unable to change the stroke width to less than 1 pt even if I select one object at a time. I thought the problem only occurred if i selected multiple strokes of varying widths.
Simon Hough
on Feb 14, 2013 at 4:32:12 pm
I found a solution to the problem. Just turn off Align New Objects to Pixel grid in the Transform panel.
Anna Surell
on Mar 14, 2013 at 6:17:22 pm
That was really useful! Thank you!
nannapat boonsanong
on Oct 12, 2013 at 6:08:20 am
Thanks a lot
Timmy De Coninck
on Mar 17, 2014 at 5:18:33 pm
Ty so much ,i've having this problem for few months
Tawhid Alam
on May 11, 2014 at 4:11:34 pm
This solved my problem. To give you thanks, I registered on this account. Thank you again for your precious help.
Jeff Horowitz
on Jul 21, 2014 at 8:51:40 pm
Wow thanks Simon, this was a huge find.
I realized that when you create a new document make sure "Align New Objects to Pixels Grid" is unchecked at the bottom.
JAH
Andray Velitchko
on Jul 24, 2014 at 5:34:05 am
You are a genious! Thank you! It really was the thing that caused the "bug".
George Flores
on Apr 29, 2015 at 8:46:11 pm
Just wanted to say Thank You so much for solving this issue. I was having such a hard time and thought I'd have to do a string of troubleshooting when I came across your fix online. Thank you and thank God for the internet. People like you make life more pleasant and comforting.
You did good. Really good.
Amy Weng
on May 7, 2015 at 8:56:31 am
Thank you, Thank you, Thank you.
This has totally saved my day.
André Tosatti
on Jan 24, 2016 at 4:40:29 pm
Thank you so much, such a little thing and it has got me so angry
christina azbill
on Apr 1, 2013 at 4:17:20 pm
Possible solution:
Open your "Transform" Panel, then uncheck "Align to Pixel grid"
Works for me :)
Sandia Advertising
on Aug 15, 2013 at 8:38:57 pm
Thank you. I was literally seconds away from chucking my Mac out the window.
christina azbill
on Aug 15, 2013 at 10:33:56 pm
Welcome! :D
rolf bron
on Jan 16, 2014 at 2:00:20 pm
Thanks for all the research, this saved me a hell of a lot of work!
Charles Blubaugh
on Apr 12, 2016 at 12:52:57 pm
Thank you. Found this by googleing the problem. I had to signup to post this thank you. What a wonderful site.
Thank you
