combining path points - non end point
COW Forums : Adobe Illustrator
buijon
on Mar 16, 2007 at 6:08:09 pm
I have some paths that I need to combine. Not all points where they visually intersect (they are separate paths but have points in the same spots) are end points. So one end point of Path 1 is in the same spot as the middle point of the curve of Path 2. How can I join these two points and make the path one path? I need to for importing into AE, it needs to be only one path the do what I need. Thanks.
buijon
Re: combining path points - non end point
on Mar 16, 2007 at 6:28:19 pm
oops...forgot to mention its Illustrator CS 2
Vintendo
on Mar 19, 2007 at 12:28:38 am
I think you need to combine all of the paths into a compound path. Select all of the paths and press Ctrl+8 (Object/Compound Path/Make).
