Export Photoshop CS to Illustrator CS
COW Forums : Adobe Illustrator
imjkw143143
on Feb 17, 2007 at 5:38:17 pm
I need to export all my layers from Photohop CS to Illustrator CS. I will need to be ablet to edit each layer as well. How can I do this the most efficient way. I simply opened the PSD in IA but all I got was one layer and none of it was editiable. I do not know if this can even be done. I sure could use some simple yet detailed assistance.
Thanx...
Mike Gondek
Re: Export Photoshop CS to Illustrator CS
on Feb 19, 2007 at 5:25:10 pm
Try saving or printing to a pdf from photoshop and opening the pdf in illustrator. Obviously check to keep vector objects and layers intact. Good Luck, let us know how this turns out.
