pen tool
COW Forums : Adobe Illustrator
edward Nahapetian
pen tool
on Feb 9, 2007 at 11:15:10 pm
hello, I made shape with pen tool & made it outline, but when I export it as a ai file in to the 3d program my shape becomes hallo empty in middle, any idea how can I coorect this?
thank's Ed.
Re: pen tool
on Mar 6, 2007 at 7:53:10 pm
It is likely that your 2D shape is importing as a spline and not a solid. A spline has no virtual mass, only coordinates.
You could construct a polygon on top of the spline.
You could extrude the spline with NURBS to create mass.
Or there might be some other function in your 3D app to generate a solid from a spline.
Note: Enabling Rulers in Illustrator allows you to define the splines center - Click and drag the ruler corner (on the top-left side of the artboard) to the desired center of the spline (path).
© 2018 All Rights Reserved
