Levels in Illustrator?
COW Forums : Adobe Illustrator
Bernd Garving
on Jan 27, 2007 at 11:09:45 am
Hi there ...
... I wonder, is there anything like the Photoshop levels adjustment in Illustrator? What to do if p. E. I want to reduce output level to 245?
Regards from good old Germany.
pixelmeister
Re: Levels in Illustrator?
on Jan 27, 2007 at 4:06:55 pm
Hallo Bernd,
As far as I know there's no "OUTPUT CHANNEL" feature in Illustrator ( like the one in Photoshop),
BUT this might work: Rasterize the image (Object....Rasterize), then go to "Filter...Colors....Adjust Colors"
and move the level sliders as desired ( to lighten or darken). You could probably even create an automated action, if you had lots of pictures.
Hope that helps.
Nochmals viele Gr
