Simple question: Quick Switch on Photoshop CS2 or CS3
COW Forums : Adobe Illustrator
djelder
on Jan 16, 2007 at 8:48:50 pm
In Illustrator you and use the Apple + ~ to quick switch from one project to the next, and I've yet to figure out which shortcuts allow for you to do that on Photoshop, but I would love to have that option if it is available, does anyone know if it's available?
Daniel Elder
Associate Producer
http://www.luminair.com
Mike Gondek
Re: Simple question: Quick Switch on Photoshop CS2 or CS3
on Jan 18, 2007 at 6:03:56 pm
Would be nice if Photoshop had that feature, as InDesign will allow you to do that also. Checked keyboard shortcuts, and did not see an option there to configure. I will suggest it though to Adobe.
djelder
on Jan 18, 2007 at 6:27:01 pm
Thanks, I do agree, it is quite a nuisance to have to go to the window and scroll through. The other thing that has been annoying me with Photoshop CS3 is that when you do the Tile Horizontally and you do some changes and apply some effects, it loses it's functionality and you then have to go back and rearrange the Tile Horizontally. I just want to set up a cascade, and then be able to quickly go from one to the next.
They have it in everything else, why not Photoshop?
Thanks for the comment, I couldn't find it anywhere in the keyboard shortcuts either.
Daniel Elder
Associate Producer
