Distributing objects evenly along a path in Illustrator CS2
COW Forums : Adobe Illustrator
jamesmaby
on Jan 4, 2007 at 8:20:25 pm
I am trying to distribute a series of boxes along an uneven curve in illustrator CS2 and having no luck doing it. It's easy to type along a path but can't quite seem to distribute objects. Anyone got any bright ideas, please?
Vintendo
Re: Distributing objects evenly along a path in Illustrator CS2
on Jan 8, 2007 at 6:13:59 pm
You probably can drag your object into the 'Brushes' palette. Choose - 'Pattern' brush. Set the 'Fit' to 'Add Space'. Now you can brush with this object, or apply the brush to an existing path.
Hope this helps.
