converting a photoshop eps into vector artwork...
COW Forums : Adobe Illustrator
00ziggi
on Jan 1, 2007 at 9:45:45 pm
i know this can be done, but i can't figure it out.
someone posted about the 'livetrace feature', but i can't find it anywhere.
Mike Gondek
Re: converting a photoshop eps into vector artwork...
on Jan 3, 2007 at 2:46:21 pm
This is done with llustrator CS2. Place the image into Illustrator. The choose
Object >> live Trace >>Tracing options
You will then be able to tweak your setting mostly for color and detail, then finally click the trace button to get yoru result. You can then use an expand command to get at the vector paths if you wish to modify them manually.
00ziggi
on Jan 6, 2007 at 4:05:10 am
thanks for the reply... so i can't do this with illustrator CS?
i used to be able to do it in version 7.... what gives?
