Illustrator CS2: Perspective and Spot Colors
COW Forums : Adobe Illustrator
cynocephalus
on Dec 6, 2006 at 11:52:59 am
Hello
I have the following problem in Illustrator CS2:
I have text which I want to transform. With the 3d effect I achieve the desired results. BUT, I need to have only Spot Colors and the 3d effect changes the Spot Color Text into CMYK text, and its now useless to me, unless I delete the effect again.
So my question is, how can I make a perspective transformation with my text, without losing my Spot Colors?
Thanks a lot
cynocephalus
Vintendo
Re: Illustrator CS2: Perspective and Spot Colors
on Dec 6, 2006 at 5:58:21 pm
Could you Expand (Object/Expand) the object than reapply your colors?
pixelmeister
on Dec 7, 2006 at 5:30:23 pm
after you create the 3d object, go to the Menue bar and choose , that'll break your object in selectable pieces, that you can colorize with your desired spot color. Hope that helps.
Adi
