HELP on Cartoonist Tutorial
COW Forums : Adobe Illustrator
dina saleem
on Nov 28, 2006 at 10:58:36 am
Hi there,
I am currently working with the tutorial of Aharon which was posted in the Creative Cow Podcast section.
I got a new computer with Illustrator CS2 installed. When I follow the instructions of part two of the tutorial on changing the code, some problems occur.
Aharon says to change the code in line 461 to (DocumentColorSpace.RGB, 1280, 720) which would be the dimensions I need. On my old computer that I had last week, it worked fine. But now for some reason and with the same version of Illustrator installed, it doesn't.
To begin with, the code in Line 461 is not the same as before. Then , when I search the document for the code and add my text to it, it opens my jpeg image in RGB but doesn't get the dimensions right.
Then when I batch process my image files the turn out to have the wrong color space AND the wrong dimensions.
I don't know what to do... what could be the problem?
I hope someone can help,
thanks
Dina
