Exporting .swf file from illustrator...
COW Forums : Adobe Illustrator
HAROON
on Nov 3, 2006 at 6:33:48 am
hi.....
Acctually i make a few a illustration for the movement of a bird using Adobe illustrator 10. and form adobe illustrator i make that movement of bird to .swf file ( 16 frame/sec). than i import that file into Adobe After Effects- in AE ... compostion also with 16 frame/sec.
but the problem which i m facing that i cant get a smooth movement of the bird. bird move with jarks...
What i do ... for having a smooth movement.
thanks in Advance.
HaROON
Andrew Kramer
Re: Exporting .swf file from illustrator...
on Nov 3, 2006 at 7:08:19 pm
What is the end medium for this bird? Are you constrained to 16 FPS? There are ways to smooth out motion, but not if you are only working with 16fps...
Andrew Kramer
HaROON
on Nov 4, 2006 at 6:08:10 am
Ist of all that for ur nice reply ... i m really thank full to you ...
after into AE - i have to make an .avi . so what should i do ... should i render my birds movement in 25-fps or 16-fps. that i can get that movement smooth ......
what should i do ???
HaROON
Andrew Kramer
on Nov 4, 2006 at 10:46:36 pm
25 FPS would be best, what you can do is put your sequence into a 25 fps comp and then turn on "high quality" frame blending with "pixel motion" on and then time stretch the layer 200 percent that way it is the same speed as your original animation but should be much smoother.
Good Luck
