Illustrator - relevel rotated text
COW Forums : Adobe Illustrator
Vintendo
on Oct 25, 2006 at 8:26:35 pm
I have an AI file with numerous instances of rotated point type. Is there any way to return this type to it's original horizontal orientation - other than manually rotating each instance?
Mike Gondek
Re: Illustrator - relevel rotated text
on Nov 3, 2006 at 8:25:17 pm
No there is not, Illustrator does not keep track of the original attributes before transformation as a page layout program like InDesign or Quark does.
Can you set a new point text with all the characters you need?
If all the type are different fonts I would set a line of point type in arial, then select each letter by characters, and use the eyedropper to sample the character attributes (size/color/font/etc). You may want to doubleclick the eyedropper prior to this and check to pick up appearance attributes also.
