How do I achieve a subtle gradient on all 4 sides of a rectangle?
COW Forums : Adobe Illustrator
heavythinker
on Aug 16, 2006 at 12:13:07 am
Hi all-
I am using Illustrator CS2 and cannot figure out how to achieve a subtle gradient for my menu bar that has a slight fade around every side of each menu button. Please see an example here. http://videoenrichment.com/menubar.jpg
I want different colors but the same type of effect. I have been playing with the gradient tool but can't make one that has the slight fade at all 4 angles (only either vertical or horizontal but not both)
Can someone please help?
Nicole
Mike Gondek
Re: How do I achieve a subtle gradient on all 4 sides of a rectangle?
on Aug 17, 2006 at 9:46:43 pm
Draw your shape adn fill with a color. Thenuse object >> make gradient mesh. Select gradient mesh points with the hollow arrow tool, and you can change their color individually or reporition them.
