When saving JPG file the file turns blue!
COW Forums : Adobe Illustrator
Lauren
on Jun 29, 2006 at 8:15:23 pm
I have no idea what is going on, but when I save things in illustrator as jpg file format the backround and the graphic turns blue. I can save as other files fine, but not jpg. I would just save it as another file however the program I am putting the image into requires jpg for some reason. PLease help ASAP if you can. Thank you in adavance!
Mike Gondek
Re: When saving JPG file the file turns blue!
on Jul 11, 2006 at 6:26:49 pm
What happens if you save form illustrator as .tif and then in phothsop do a save to .jpg. Try use save for web from illustrator and choose jpeg there.
I have seen white backgrounds chaneg to blue due to an incorrect color mangement setup, but not the entire document. Do your images look like blue monotones. I would turn off color management temporarily and see if your problem continues.
