Using vector paths
COW Forums : Adobe Illustrator
David
Using vector paths
on May 23, 2006 at 8:03:58 am
Hi people
I am using Illustrator CS2 and want to use Vector paths to draw an image. Then i want to import that image in to Zaxwerks pro animator. How do i access Vector paths so that i don't get any error messages when i attempt to import the file in to pro animator?
thanks
David
Mike Gondek
Re: Using vector paths
on Jun 1, 2006 at 8:24:25 pm
Never got to use Zaxwerks, btu you can try to copy a ptath to the clipbaord and paste (works in After Effects if you have your illustrator preferences set to aicb)
Otherwise you may want to reference what file format s zaxwerks accepts (pdf, eps or .ai) If you use .ai you may wnat to try turning off or on PDF comaptibel when saving.
Sorry I don't haev Zaxwerks expereince, but noone answered your post so hope this helps.
