what have i done wrong?
COW Forums : Adobe Illustrator
evrard
on May 14, 2006 at 3:06:18 am
I was trying to create a 3D object in proAnimator (and in invigorator) from an AI file.
ProAnimator says "there is no usable vector path in your file" and closes.
How did i create the AI file? I simply opened Illustrator CS2, grabbed the pencil tool and drawn. I then saved as AI. And i clearly see the drawn object within Illustrator.
Was there something alse i should do in AI? what does this error message mean? What is a "usable vector path" and how is it different from what iam seeing in Illustrtor right now?
Thank you
PS: I am totally new to illustrator.
Joe
Re: what have i done wrong?
by
on May 15, 2006 at 7:48:16 pm
Did you try saving as an eps?
evrard
on May 16, 2006 at 10:25:07 pm
Yes i did. But definitly unchecking the "use compression" helped fine.
Thank you guys for being helpful :)
Wildfire
on May 22, 2006 at 11:58:44 am
Try exporting as an eps, then exporting as an AI file rather than saving as one. You may need to back track and save/export as Illustrator 8 format.
