DWG format disappeared....
COW Forums : Adobe Illustrator
antonio
on Apr 22, 2006 at 8:52:49 am
Hi. a little technical problem here....After an Illustrator cs2 closing error when I click on file open there isn't the dwg or dxf file format ...
I tried to uninstall completely and reinstall but is the same thing...
Is there a script or something damaged that I could relaunch to reinstall the dwg format (in file/export all is ok and the dwg format is present)
Any tips is welcome....
Thanks a lot...
antonio
Re: DWG format disappeared....
on Apr 26, 2006 at 3:20:38 pm
None with the same problem?
thx...
Antonio
on May 6, 2006 at 8:20:59 am
I solved this strange thing....
I installed a demo version of illustrator cs and after that the format dwg and dxf reappared in illustrator cs2 too.....this is a really strange thing.....but anyway it solved the problem....
I hope this could be useful for anyone.....
bye :)
