Illustrator 10 Crop Photo Problem
COW Forums : Adobe Illustrator
scoast
on Mar 8, 2006 at 10:08:00 am
Hi, Just wondering if anyone knows how to crop photos in Illustrator 10. I've tried using the crop pathfinder without any luck. Thanks for any help : )
Kim Mackenzie
Re: Illustrator 10 Crop Photo Problem
on Mar 8, 2006 at 12:45:42 pm
Draw a box or shape on top of your photo at the size you want to crop it (set the fill and stroke to none so you can see what's going on).
Select both your photo and shape and go to menu Object > Mask > Make.
If you want to adjust the size/location of the mask, you can do so by grabbing and moving points with the white arrow selection tool.
scoast
on Mar 9, 2006 at 2:32:27 am
Thanks for the tip! That seemed to work. Now, is there anyway to isolate just the clipped graphic and get rid of the outlines of the two original shapes?
