change paths with stroke to a solid shape with no stroke but same thickness?
COW Forums : Adobe Illustrator
honion
on Feb 20, 2006 at 6:20:48 pm
I know that subject line is a little bit of a rambling thought, but... I have created some text in Illustrator and converted it to outlines. I needed the text to be thicker looking so I put a stroke on the outlines. Is there a way to change the appearance from stroked to fill only while maintaining the same look?
Kim Mackenzie
Re: change paths with stroke to a solid shape with no stroke but same thickness?
on Feb 20, 2006 at 6:23:34 pm
I think you'll get the look you want if you also fill it with the same color that you've stroked it with.
honion
on Feb 20, 2006 at 6:25:14 pm
Nevermind I answered my own question...Outline stroke...so simple!
