custom text justification
COW Forums : Adobe Illustrator
Todd Morgan
on Feb 7, 2006 at 10:13:09 pm
Hi there,
Any thoughts on how to justify text along a custom curve, instead of using Quark? Is there a way to use paths and type to do this?
Todd
Todd Morgan
Creative Director
Freelance F/X Inc.
Richard Harrington
Re: custom text justification
on Feb 8, 2006 at 2:36:11 am
Both PS and Ai do this (newer versions)
Look up text on path
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
edit - produce - direct -
Todd Morgan
on Feb 8, 2006 at 3:01:25 pm
I don't want the text to follow a path. I want the text to justify along a path.
Kim Mackenzie
on Feb 8, 2006 at 5:39:49 pm
Sounds like you want a Text Wrap.
- click and drag with the type tool to make your text box
- in the Paragraph palette, turn on Full Justification
- select the path you want the text to justfiy to, go to Object > Text Wrap > Make Text Wrap
- you'll get a dialog box where you can set the width of the buffer around the object.
Todd Morgan
on Feb 8, 2006 at 8:06:33 pm
In Photoshop CS???
Kim Mackenzie
on Feb 8, 2006 at 8:40:59 pm
Assumed you were setting type in Illustrator, to which the above instructions apply.
I don't know of a way to do that in Photoshop.
Todd Morgan
on Feb 8, 2006 at 8:47:07 pm
Thanks! Working with Illustrator CS and it is great! Didn't realize I could open a Photoshop file and access my text. Cool!!! Thanks for your help!!!
