Converting illustrator 11 to illustrator 10
COW Forums : Adobe Illustrator
Cathleya
on Feb 3, 2006 at 9:02:18 pm
A client gave me a file created in illustrator and I only have illustrator 10. every time i open it it says "cant open illustration, the file was generated by a newer version of illustrator and cannot be opened, please resave it in a format compatible with your vers of illustrator".
I resave the illustration in 10 and it does not appear to be anything. Meanwhile i open the file in Photoshop and I can see the artwork (so i know that it exists)
how do i "down convert" the illustration to 10 so i can keep the file as the original EPS? Is this even possible?
Richard Harrington
Re: Converting illustrator 11 to illustrator 10
on Feb 4, 2006 at 12:17:46 pm
Download the 30 day demo
Open file
and save a legacy version (command moves) can't remember exact location export or save as.... but listed in help menu
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
edit - produce - direct -
