EPS COLOUR CHANGE
COW Forums : Adobe Illustrator
Roger Burton
EPS COLOUR CHANGE
on Jan 26, 2006 at 6:00:14 pm
Hi all i've also posted this on the After Effects forum but had little luck ... maybe one of you gurus could help.... I've just brought an eps (RGB) into AE (don't know where it originated) and AE has changed the color quite dramatically so I then opened the eps in pshop converted it to a psd and saved it and the colour looked a little better .... certainly the color values matched what they were in pshop ... but just to double check I opened it in Illustrator and the RGB readings are different .... can anyone tell me where this change is happening ie what I see colour wise in Illustrator I'd like to see on Pshop and AE and I don't think I've changed any profiles .... thanks for your time ... Roger
