LIve Trace in Illustrator --- DO I HAVE THE OPTION
COW Forums : Adobe Illustrator
FoxxieFrannie
on Jan 5, 2006 at 11:01:22 pm
I was watching the live trace tutorial by Frank and I would love to incorporate it into a brochure I am doing. HOWEVER, it was in Illustrator CS2. Is this function available in the much older version 10.0.3?
Very big thanks.
Troy E. Parker
Re: LIve Trace in Illustrator --- DO I HAVE THE OPTION
on Jan 6, 2006 at 12:15:42 am
Hi ,
This very cool feature is new to CS2. To try it out, you can download a trail version of CS2 ( good for 30 days) and play with all the neat feature that are in Illustrator CS2 ( & CS) over version 10. Chances are you will never want to return to the old ways...
Have fun!
Troy
troy@crossmediacorp.com
http://www.crossmediacorp.com
Clif Willard
Re: LIve Trace in Illustrator No Center Line trace.
on Nov 23, 2010 at 2:14:30 am
In Adobe Dimensions, you had the choice to trace with the result of a center line,( single path). I cannot find any such option in live trace. When I try to trace a line drawing I get closed paths around the lines no matter what parameters I use. Was this feature excluded from live trace? I still have my dimensions but it certainly would make life easier if I could do this in AI 3.
Thanks for your thoughts.
Clif
Clif Willard
NON ILLIGITIMI CARBORUNDUM
