Illustrator illustration
COW Forums : Adobe Illustrator
kim
by
on Dec 31, 2005 at 10:39:53 pm
Hello,
anyone know how this effect is done in Illustrator?
http://www1.istockphoto.com/file_thumbview_approve/1040335/2/istockphoto_10...
/Kim
Richard Harrington
Re: Illustrator illustration
on Jan 2, 2006 at 11:44:55 pm
That's raster and probably done in a 3D program
Richard M. Harrington, PMP
Author: Photoshop CS for Nonlinear Editors
Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
edit - produce - direct -
kim
by
on Jan 2, 2006 at 11:53:04 pm
ok, I thought so myself but Istock claimed it was made in Illustrator so I was just curious. Thanks anyway!
Del Holford
on Jan 3, 2006 at 5:54:21 pm
Hi Kim
Something similar can easily be done in Photoshop using the stylize>extrude filter, which makes blocks. I did the extrude on a photo, put a distort>twirl on it then another stylize>extrude and got an interesting effect. Not sure what you need but thought I'd throw in the thought.
Del
Del - fire*, smoke*, photoshopCS Charlotte Public Television
Andrei Lutic
on Jan 6, 2006 at 8:35:14 am
I think you can make something similar in Illustrator. First you must paint all those rectangles using a scatter brush with the size, spacing and scatter set to random. After that group them and create the 3d effect using envelope distort with mesh or top object. HTH
